wrx injectors
nonchalant rage
Car: s12
i just bought some 420cc wrx injectors for my ka-t project. i just noticed that theyre top feed instead of side feed, what would i need to do to make these work? i picked them up for $100, so it isnt a big deal.
Structure240sx
some kind of a top feed fuel rail. not exactly sure if you will need a custom on or if you could make a jgycutoms or jwt work. i do have a jgy fuel rail sitting around. not sure if im going to end up using it or not yet.
also you will most likely need the injectors plugs from the wrx to splice into the ka harness
nonchalant rage
Car: s12
could i possibly use a ka24e fuel rail? theyre top feed.
Structure240sx
if the placement of the injectors are close enough and it it bolts up or you make brackets im sure it could work
S13ChucKAT
Car: asd
but beware.. if those injectors arent perfectly squared (like.. fuel rail, and injectors isnt exactly 90 degrees Straight.) the O-rings will leak fuel.. do a little measuring before you invest in something you cant use
