WRX injectors??
LoserbabyS13
Car: 1989 240sx w/ CA18DET and 2003 WRX
can wrx injectors be used in the ca. I am not worried about high or low imp as I have SDS and can switch if need be. I am wondering if they will fit physically?
wrx sti injectors
Spectre23
Car: S13 CA, 2013 STi, Tony Kart
Isn't the WRX sidefeed like the SR?
LoserbabyS13
look at the link!
float_6969
I don't think they look like they would. Not with out some sort of custom fuel rail anyway.
Daemos
Car: '03 Spec V
A little off topic what's the diffrence between high imp and low imp injectors?
mikesim
they are litterally low impedance and high impedance. low impedance injectors measure 2-3 ohms. high impedance are of course alot higher.
i don't know how they differ in function.
Daemos
Car: '03 Spec V
mikesim wrote:they are litterally low impedance and high impedance. low impedance injectors measure 2-3 ohms. high impedance are of course alot higher.
Ah you're on here too haha :)
So all it is is diffrence in voltage resistance, so I'm guessing how much voltage the ecu needs to send to get a certain flow I'm geussing...
Ps did you get your FMIC in yet? You still owe me a rip in it (whenever you have time, I'm in no rush :) ) You're also STILL the only silvia I've seen in the city.
