yashin wrote:well the guy said that yellow wrx injectors fit directly
USDM WRX injectors (02-05) are blue top feed injectors (these are the ones everyone mods)
The 2.5RS' use sidefeed injectors, but if you get a '99 intake manifold (SOHC but no air assist) if you use '99 injector O-rings and the blue top feed injectors they fit fine with the RS stock fuel rails.
So you might be able to use the top feed blue WRX injectors with some kinda custom rail setup, spacers for the rail or the right O-ring combination.
I can't say for sure as I haven't looked that closely at 240sx rails lately. I have have an opportunity shortly considering I have friends with 240's and some spare USDM WRX injectors floating around in my spare parts bin.
I was going to use WRX injectors in my RS-T but decided to run some 550cc low impendence RC injectors instead. (by the time I need the 780cc injectors, I'll probably need even bigger for something even crazier)
