VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Mon Mar 07, 2022 9:41 am
The valve body will definitely be shot, it only takes a couple teaspoons of regular ATF to screw them up. But you can't just replace the VB, there will be ATF inside the torque converter which will be impossible to flush. If it can be saved at all, the tranny will need to be split away and the converter replaced along with the VB, and all the passages purged with solvent and compressed air while the VB is out.
