PoMansVan »
https://forums.nicoclub.com/pomansvan-u273551.html
Sun Jul 16, 2017 7:37 am
I know if you search the interwebs, you'll see lots of alleged and many legit issues with CVTs in Nissans, but I haven't read of many (or any?) with 2011+ Quest minivans. Time will tell I guess. 2011 through ~2014 use one version of Jatco CVT while the 2015-16 use another. Hopefully yours doesn't need a total transmission replacement and if so, hopefully at no cost to you because like any transmission, they are NOT cheap. Best case you've got nice fresh fluid in there after they swap that out. If you're into DIY maintenance, draining and refilling the CVT oil is as easy, if not easier than an engine oil change on these. There's no magic. They have an easily accessible drain plug, a dipstick to refill from and a level check plug. Simple.
