DrewQ45 »
https://forums.nicoclub.com/drewq45-u2328.html
Thu May 04, 2006 4:39 pm
Buy a small hand siphoner at any auto parts store...
This is an object with two hoses attached to a rubber bulb which sits in the middle between the hoses. First suck the reservoir tank dry by siphoning into a container which you place on the ground (of course the bottle must be lower than the reservior for the gravity siphon to work)... You must buy a siphon with a nice thin hose. Hopefully folks know how to use a siphon?
Once the reservior tank is empty, look for the hole in the bottom which is the supply hose leading to the steering rack. Stick the siphon hose down into the hole and push it as far as it will go....it will be inside the main hose leading to the rack (this is why a thin hose is important)... then siphon until you get air. Fill up with ATF then turn steering lock to lock with the car on a few times. Check fluid again and add if necessary. Do this about three times for 1 week (for initial flush) then every 3 oil changes/ once a year and you should be fine. Personally I use el cheapo Dextron III ATF fluid and replenish as described. Nothing wrong with expensive Mobil for peace of mind and lightness of pocket though.
...Drew...
Modified by DrewQ45 at 10:52 PM 5/4/2006
