ali wrote:on the back of the centers look at how thick the hub is. If its thick (maybe 2" or so) then iforged or a shop can shave it down. its a easy fix as long as you have a little bit to shave.
let me know what if what i said doesnt make sense.
*****WARNING*****
You cannot just shave the backpad down !!!!
You need to be careful about how much material is left after shaving the backpad to make sure your lugs have enough material left to mount on. The lug holes in the wheel are wide towards the face of the wheel, but taper down to the size of your studs as you go towards the backpad. If you shave too much off, there will not be enough material on the back portion of your wheel to hold the stud/lug. To do this properly, they would have to weld the holes, then shave the backpad, then redrill the holes to the proper depth.
If they wheels are flush to the fenders, then you will have to run a stretch tire so the tire will at least tuck, but I'm not sure if you're lowered or if your wheel will hit the fender when loaded up or if you go in a dip where the suspension is fully depressed.
