alphacode wrote:Also liquid you always post something helpful, I need you in a pocket version to check my mistakes when i'm covered in grease freezing my a** off and wondering what i did wrong cuz i was in a hurry.
Any how thanks!
dude..thats what us nicco heads are for....we may not have all the answers as induvidualls...or good spelling..lol...but we do as one big a** nissan lovers forum bro...the power of many!..
anyways..to your issue.....you can blow out your lines with like 100psi clean air!...but remove your master and clean that out by hand..you dont want to blow out the seals as there a pita to fix....you can allso try spraying some brake clean in the lines before you blow it out to break down the greese...id actually do a couple of cans to be shure you dont miss any left over..then blow it clean..bleed system...and if you still dont feel the pedle is what it should be...drop the transmission and investigate the clutch and fork..keep us posted man on this issue..and welcome to nicco!
