mRodiek »
https://forums.nicoclub.com/mrodiek-u91521.html
Mon Feb 02, 2009 4:12 am
Maintaining Your 240sx During Winter
Your car covered in snow.If your car isnt on the driveway like mine then watch your step & wear sneakers you dont care about.Take your toolWipe as so..Starting on top & working your way downBe careful of attatched objects such as the rear wiperNext you need to remove the snow under the wing, if you have oneTake your glovesAnd pull the snow out as so..Dont forget the backThis will help prevent moisture from building up under the wing and causing rust.Also check under the car for leaves/grass etc that has built up, I had nuts and animals building a small hill up into my engine bay.You COULD keep your windshield covered to prevent dask crackingOR use a target bag like I didCheck your tires as well, you do NOT want your car to be sitting on a flat/directly on the wheel all winter.This one was okThis one tooThis one is NOT ok! Filled her up to 34 psi right away.CLEAN!
You should do this as often during the winter months as possible if your car is outside & not on a solid surface. Also, I have a carbon fiber hood so I make sure to at least wipe that off because you dont want all the weight from the snow weighing it down. You can get very detailed and wipe 100% of the snow off the car, and cleaning out under the windshield wipers is a good idea as well
