exactly why i want to do a write up, so that people whom arent experienced with soldering have more explanation than that on the back of the package your iron came in. In addition to that, I can give advice as to how to make the connections in a manner in which the wires can be tied off easily and the connections are extremely sound with good conductivity and strength.duffman1278 wrote:Yea, I don't solder, rarely ever.
Yea pics would help, thanksWhite Comet wrote:since the soldering has already been discussed, i figured i'd let u know theres an easier way to wire the a/f ratio gauge. instead of going to the O2 sensor you go go to the same wire, just catch it where it goes to the ecu. it does the same thing its just easier then going to the engine bay. i can take pics and show the exact wire to go to if anyone wants
yeah i'll try to get pics later but its snowing so we'll seeduffman1278 wrote:
I have one, I could probably send it to you, cause when I ordered mine, they gave me a packet of like 10 and I have about 5 in my drawer not used. I could probably put it in an envelope and send it to you?positronone wrote:That looks like the "ferrule" that they refer to. That's the part that I can't get to tighten up on the pressure hose.
I've got one but it just slides around when I put it on the nylon pressure line, could I not be tightening the compression nut and adapter enough when I put them together? I don't want to overtighten it and mess up something.duffman1278 wrote:I have one, I could probably send it to you, cause when I ordered mine, they gave me a packet of like 10 and I have about 5 in my drawer not used. I could probably put it in an envelope and send it to you?
Yes! This is what I needed to know! Thanks again!duffman1278 wrote:Well when you put it in, it should slide but when you tighten the bolt, it'll compress it to where you can't take it out, trust me, i've tried to take mine out from the nylon hose. Try tightening it up a bit more.
