WRITE UP: Hockey Puck Motor Mounts.
KEMP
Car: 1990 240sx CA18DET
Hey guys, new here, first post to be exact, but I figured I would do a quick wirte up on my DIY motor mounts, first I would like to say they are VERY stiff, and do cause vibration, but is well worth it and made my car a different feeling and handling car.
Things needed-4 good hockey pucks-2 3" 5/16 bolts-4 large washers-2 self locking nuts-drill-patients
Drill through the pucks to make a snug fit for the bolts
pull old motor mounts(jack up car the motor via oilpan and block of wood.
place a large washe on both inside sides of the 2 hockey pucks(2 for each side stacked) for space/cushion.
place bolt through bracket on motor then through pucks.
then through the cross member hole, MAKE SURE to use washers on the bottom cross member or you will find that the nut will come through the cross member bolt hole.
tighten down nice and tight and find all your new vibrations/rattles in the car then tighten theose up as well
Take for a ride, and notice NO engine movement, check nuts for tightening every day for a couple days.
Enjoy, and im glad to be here
Thank you
schanne
Car: 93 Hatch-Sr20
Welcome to Nico! Good first post. However a write-up with no pics? Post some pics up...
KEMP
schanne wrote:Welcome to Nico! Good first post. However a write-up with no pics? Post some pics up...
Thanks, Pics will be up tomorrow, i have some left over wahser ill take a couple pics of, and ill show what they look like on the car, very clean look.
my n62, 444cc, and VMIC write up will be here in the next couple months.
YES i said VMIC, haha
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Nice post! I am going to give this a try over winter break. I want something stiffer than Nismo mounts, and not quite as painful as solid aluminum, so this looks good. Can't beat the price either.
HighwayStar22
Car: 2002 RSX Type-S, 1991 240 Hatch
r34 gtr wrote:Nice post! I am going to give this a try over winter break. I want something stiffer than Nismo mounts, and not quite as painful as solid aluminum, so this looks good. Can't beat the price either.
Hater.... hahaha J/K. I still have a nismo transmission mount though. So it's all good.
bentvalves
Car: 89 Silvia K's
you could always fill your nismos or stock mounts with window weld.
works nicely.
r34 gtr
Yeah? I don't know... sounds even more shady than some hockey pucks.
HighwayStar22
I meant to only bold up the part about the solid aluminum, since that's what I've got.
Darn thing highlighted it all. Probably just operater error though.
iliketocrash
personally i feel the flexane motor mounts are the way to go. but that's just me
D_Stirls
Car: Nissan 180sx 1990 Ca18det
EDIT!!Sorry KEMP for crashing your thread;I made a set of engine mounts from the softest grade of urethane that i could machine (it's slightly softer than tyre rubber on the rigidity scale). I still found that the vibration that was passed through was unliveable. I put this down to the bolt that runs through the centre of the mount.
I ended up scrapping that design and went looking for suitable engine mounts the could be modded to fit. I was suggested to look into Mark 2 Escort engine mounts, which is what i did and they are perfect.
The mounts themselves are still made from urethane but they don't have a bolt that runs through the center and there is 0 vibration. Interestling thought there is also very little movement, infact try to move the engine by hand and it won't budge at all.The mounts themselves are 53mm high as opposed to the S13 mounts which are 65mm which is why i machined up the aluminium spacers as well as with the cup to bit of heat protection on the turbo side.
Modified by D_Stirls at 11:07 AM 11/4/2008
iliketocrash
this is the link for the flexane write-up. probably should have posted that the first time. on a side note. How long have you been running the escort mounts, D_Stirls?
D_Stirls
About 3 months now.
rico05
Car: 1992 RMS13 w/ CA18DET
Nice write up.
I am really happy with my window weld filled stockers though. Rigid, but no annoying vibrations in the cabin.
