In
pathfinder-qx4-general-information-and-q-a-t549378.html, towncivilian
correctly points out that the hole in the differential plug is 13mm, 1/2 inch (12.7mm), and points to an
inexpensive Harbor Freight set. I see two problems with the Harbor Freight set: 1) it's Harbor Freight,
2) it fits 3/8" tools, not 1/2"
Here's a couple of other options:
A)
http://www.ultimatetoolco.com/drainplugs.aspx It's pricey at $29.50 for a single socket, but looks
very well made. Besides the 1/2 socket connection, it also has a hex head that will take a 24mm wrench
for close quarters. It's also out of stock at the moment.
B. K-D Tools used to make a wrench, their p/n 2329. It's not in their current catalog. I picked one up in
an auto parts store about 30 years ago, and ran across it today in an obscure corner of my tool chest.
It's not a socket, it's just a piece of steel about 1/8" thick with a 13mm square piece on one end.
If it were still available, I'd guess it would be about $10 today. I couldn't google one up, but it might
be worth putting a watch on eBay.
At least Pathfinder HAS differential plugs. My '87 Corvette has no drain plug. You have to pull the back
off the diff to drain the oil
Chuck
