justmerging wrote:To all those who keep saying the brakes on the V suck, I will have to disagree. The actual braking system is overkill for this car. 11" front vented rotors are enough to haul a 300zx too a stop in a resonable distance, I don't think they would have a problem on our little 2700lb compact.
"You think"? Meaning you've never tried it? Go ahead, try it. You'll understand what we're talking about.
You're right about the front brakes being overkill for the car. It's the REAR brakes that suck, and also what causes the car to fishtail. Remember, your inertia does not rest ENTIRELY on your front wheels.
If it were simply a matter of "Crappy tires", then the car would not have the tendancy to consistently fishtail. But because your rear has so much more inertia than your front, you WILL fishtail. Every time. The ABS helps negate this, but can't completely neutralize it.
motoguy128 wrote:I agree with "Justmerging". The stock tires are pretty crappy on this car. Tires make a huge difference. It one of the major reasons that SUV's have poor stopping distances. I think also, this car is a little heavy for the tire size. While smaller tires are good in snow. On wet and dry pavement, it would benefit from 205 width tires.
Overall, I don't think this car is any worse than the others in it's class if they had the same junk tires.
Wrong again. The Kia Spectra is in the same IIHS class as the Versa. (Those who actually read the IIHS site, not just the AP articles, will note that while it was tested with minicars, it was classified as a small car due to the fact that it is so much larger).
I owned an '02 Spectra, brand new, which was equipped with equally crappy Hankook OE tires. It would always stop sure, straight, and reliable, and would ONLY fishtail or skid during heavy braking on curves in the wet.
The '02 Spectra was equipped with the same width and diameter of tire as the V, is of a very similar weight (in fact, the Spectra was actually a few pounds heavier), was also a front disc/rear drum setup without ABS.
No, I truly believe this is a case of bad brake design. I bet if you put a bias adjuster on it and sent more power to the rear brakes, it would at least stop fishtailing. Disc brakes would also help.
Wider tires would also help, but they would also create both more wind drag and more road drag (from the increased surface contact patch), so that would decrease economy.
Right about now I'm wishing I still had my old ADR type 29's with Proxes FZ 4's at 205 width to drop on the V and prove my point.
