C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sun Jun 06, 2004 9:20 am
If the insurance company backs the work at the shops on their list, I'd probably be more inclined to take it there. Chances are if an insurance company will use them, the shop offers their own guarantee. And this would be doubly backed by the insurance company, which would mean that ultimately, if the shop can't get it right, the insurance company will likely allow you to have it repaired at another place at their cost and then take the matter up with the body shop that couldn't do the work. Take it soimewhere else, and it might end up being a situation the insurance company will not touch. If you are adamant about using a dealer recommended shop, most insufrance companies will have a few that are associated with dealerships on their list. It may not be from the same make, but as I said before, body work is fairly universal.
I'm not saying not to take it to a dealership, but I wouldn't rely on that alone to pick a good shop. I've seen issues with dealer associated body shops and independent shops.
And Robert, just to clarify, with any paint and especially metallic paints, it's impossible to get a perfect match. Paint manufacturers spend a lot of time trying to get a good match to new paint. But paint wear and tear exists. Paint can fade over time from UV rays and weathering. Painters will use the paint manufacturer's specified paint mixtures then tint the color as needed to get as close a match as possible. Then they blend the paint. If any of the major panels on your estimate are being replaiced or in some cases also when repaired, you will notice a line for the next adjacent panel to be blended. This means they paint partially into the next panel, basically fading the paint so any differences in color are gradually shifted. This is of particular importance on metallic paint as the metallic flakes can be hard to align the same way as the factory, so a blend is needed. If there is no blend, the two panels can look like completely different colors as light will reflect differently off of it. Just be happy you don't have a pearl in your paint. This can be particularly hard to match. There is in fact no set way of doing it. They basically keep pblending a pearl into the next panel until and differences can not be noticed.
