Brandon1605 wrote:How are you wrapping it? Are you starting at one side and working your way across?
I've been starting in the flat part of the dip (arm rest area, above the switch), and then working my way out.
They also spray the glue on the surface being wrapped first, not as they go.
I've tried doing it as I go. How can I spray the whole surface without having the material stick prematurely to it? Also, it's harder to stretch if the material isn't "anchored" down to the panel. I wouldn't be able to stretch over the "corners" without it sliding or lifting.
Also, Im fairly sure you should be using foam backing.
I'm going to try this next (first vinyl had a mat, second had cotton). I want to figure it out, a lot of people on here could use a good tutorial.
charat wrote:this is the same guy who uses jelly as an adjective. 1st grade, bro. repeat it.
u jelly of my exotic adjetives?
krash wrote:What kind of adhesive are you using? and what exact problem are you having now?
I'm using 3M Super Trim Adhesive, the spray kind. The spray itself works well, but the cotton backing of the last vinyl I used wasn't glued on too well from the factory. Stretching it caused the vinyl to separate on concave curves.
Gameplan:
1. Buy 4-way stretch vinyl.
2. Buy foam backing.
3. Spray door panel and one side of foam, let airdry for 5-10 minutes. Lay. Let dry.
4. Spray foam and bottom of vinyl, lay. Let dry. Repeat in small increments.
Should be it! I found someone who did something similar. Didn't turn out as well as I'd prefer, but I'm going to take my time and hope for the best:
http://forums.corvetteforum.com/c4-gene ... ideas.html
