wow =/
Angerman
Car: 89 240sx
took my car to a local shop in fl to fix the oil feed line so they fix the line and i pay and leave drive a block the turbo WHISTLES LIKE CRAZY i come back i said wtf is going on this car wasent making this noise so now they said it was the turbo... i will post a video tomorrow this is a GT28RS turbo they said they not responsible bcuz the car was towed there could of been like that b4 they got it http://www.youtube.com/watch?v=S0GEM_-NFmIITS DOING THE SAME THING THIS CAR IS DOING IDK IF THEY threw something in my tubro im f***ing pissed
Modified by Angerman at 6:13 PM 9/30/2009
Nali
Car: Datsun Nissan 280ZX
Was it the turbo Oil feed line?
If it was then your turbo is most likely toasted cuz they didnt prime it. So when you started the car the turbo had no oil and raped itself anally
Thats my Hypo anyway.
Angerman
Car: 89 240sx
yeah nali it was the oil feed line im sure thats what happened... so now i was thinking of getting this for now because im freaking broke.. lmk what you think and if i should get it
http://cgi.ebay.com/ebaymotors...ories
PorkChopExpress
Car: rb kouki
why did the line need to be replaced? the 1-2 seconds of no oil on startup wouldnt kill it especially a bb one. did you take your intake off and check for play, does it turn freely?
white_ashes
Car: 1969 Datsun 510
Angerman wrote:yeah nali it was the oil feed line im sure thats what happened... so now i was thinking of getting this for now because im freaking broke.. lmk what you think and if i should get it
its just a downpipe........turbo and mani sold separatly.....looks ok for ebay stuff but should look into something name brand....just my opinion
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I dont think it was a priming issue.... You were having it replaced for a reason, perhaps that reason ran her dry?
Angerman
Car: 89 240sx
so when i replaced the gaskets off the manifold i made a mark on the turbo and on the manifold... comes out that the mark is not there and they changed my turbo he said he didnt start the car before so he cant replace it... f***ing ***holes...
OutToWinPAHC wrote:I dont think it was a priming issue.... You were having it replaced for a reason, perhaps that reason ran her dry?
thats prolly what they did once they put the line ran it dry because the turbo had like 3k miles on it was freaking new can ran beautiful before taking it to the shop..
PorkChopExpress wrote:why did the line need to be replaced? the 1-2 seconds of no oil on startup wouldnt kill it especially a bb one. did you take your intake off and check for play, does it turn freely?
yeah it turns freely also when i turn on the car and rev it up a little bit then i shut it off the turbo still makes noise with the car off for like 5 secs the same thing as the audi vid i posted same noise
Justin35ll
Car: s13 coupe sr20det
unfortunately, your turbo is blown because of the lack of oil it didn't get. well it probably still makes boost it just whines because it has shaft play and is scraping against the compressor housing
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
used to live in Pompano / Margate / coral springs. Was it a certain Z shop off 441?
ZOMG.SR20
Car: 1990 s13
sounds like how my turbo did... but it wasnt blown it was because I wasn't using a restrictor.... now i am and no moar whine
Angerman
Car: 89 240sx
Justin35ll wrote:unfortunately, your turbo is blown because of the lack of oil it didn't get. well it probably still makes boost it just whines because it has shaft play and is scraping against the compressor housing
yeah i guess im just gonna have to get another turbo
OutToWinPAHC wrote: used to live in Pompano / Margate / coral springs. Was it a certain Z shop off 441?
they do everything its by andrews blvd maybe its just my bad luck =/
ZOMG.SR20 wrote:sounds like how my turbo did... but it wasnt blown it was because I wasn't using a restrictor.... now i am and no moar whine
what do u mean u werent using a restrictor u have pics?
White Comet
Car: fc, s13 and mazda6, Sierra
its the fitting that goes from the turbo to the line only it restricts the amount of oil going in
Angerman
Car: 89 240sx
White Comet wrote:its the fitting that goes from the turbo to the line only it restricts the amount of oil going in
yeah apparently when i took it to get the oil line screw fixed that goes to block they rethread it and put a bigger bolt
ZOMG.SR20
Car: 1990 s13
theres your problem the bolt's too big
Angerman
Car: 89 240sx
are you serious? i thought more oil would go through OMFG so i cant put a new turbo and prime it the right way now fuk =/
Angerman
Car: 89 240sx
he took the banjo bolt out and checked if it was getting oil... and it was he took banjo bolt out a bit and oil came out...... =/ how do i check if the turbo is getting or got oil the turbo is out right now =/ lmk asap please need the car to run
