GotdaDrift »
https://forums.nicoclub.com/gotdadrift-u34717.html
Mon Feb 16, 2009 11:19 am
I have a extra Ca motor trans set sitting around in Jersey and was curious to see what you people would be willing to pay or even what this would go for. I was gonna start building up but times got tough so it was abandoned. As it sits i have a ca18det motor and trans some of the brackets have been painted Gold to go with the theme i was going with It has a after market turbo manifold, brand new Spec stage two clutch. wiring harness solid steel motor mounts and factory ones plus everything else that came with the set stock manifold, heat shields exc exc the only down fault is the turbo I pulled it being it had bad shaft play and never reinstalled a new one so the old stock turbo is kinda just sitting there Tell me what you guys think
