govtworkhorse wrote:whats the best way to do a leak down test? Just get a valve stem and an end cap and pressurized the system and wait?
thats not a leakdown test, a leakdown test is when you pressureize individual cylinders when they are at TDC on their compression stroke and measure the amount of air that escapes. think of it like a super accurate compression test that tells you if you have an internal problem
what you are thinking of is just a boost leak tester. i would highly reccommend making one. they cost all of 3$ and you can get the parts at home depot and a tire shop.
lean on decel is normal. so is 20 inches of vacuum on decel. youve just never noticed it before. actually your idle vacuum is a little low i would check your ignition timing too.
you probably still have a boost leak.
