fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Sun Sep 04, 2005 7:43 pm
Okay, some vocabulary for the not-so-automotively-inclined:
"Turning Over:" Also referred to as "cranking," this is the sound of your starter actually moving the engine in order to get it started. You hear this every time you start the car, usually it takes one or two rotations before the car catches and starts up. If you hear this sound, that means that your starter is working.
Again, keep it simple. If the engine is not cranking - as I described above - follow these steps:
1. Take your battery out and have it checked at a local parts store- they will make sure it is fully charged.2. If that works, great. If not, try tapping your starter a few times (lightly!) with a hammer or metal rod.3. If that works, sweet. If not, it is most likely your starter that is the problem. Take it off (only 2 bolts holding it in), and bring it in to your local auto parts store. They can tell you if it is broken or not before you buy a new one.4. Replace the starter if necessary. If the starter checks out fine, start looking for wiring issues. Given what you've posted so far, this probably means that you should take the car to a mechanic.
If the engine DOES crank (as specified above), follow these instructions:
1. Fill up your gas tank, or at least add a few gallons.2. If that works, cool. If not, crank the engine twice for 5 seconds each time. Pull the spark plugs out, look at them and smell them. If they are wet with fuel, that is good. If they are dry as a bone, you probably have a fuel pump or other wiring issue. See a mechanic.3. If the plugs are wet, attach a spark plug wire to one of the spark plugs while it is still out of the engine. Lay the spark plug with attached wire across the valve cover so that the tip of the plug is close to the metal of your valve cover. Have a friend crank the engine a few times while you watch the spark plug. You should see spark arcing from the plug tip to your valve cover. If not, see a mechanic.
If none of that works, see a mechanic.
