TwoaForteeEssex »
https://forums.nicoclub.com/twoaforteeessex-u94359.html
Thu Apr 10, 2008 8:48 am
k guys. i have a 93 240sx DOHC and it was running good until one day it just died while i was driving. thankfully i was already in my driveway so i just rolled in. i took a look at the engine and i wanted to see if i got spark or fuel. i got fuel. but no spark. so i pulled my distributor and it was siezed. it wouldnt turn. and a couple teeth on the gear had broken off. so i changed the distributor and while i was at it the spark plugs, wires, cap and rotor. put it all back together and put TDC and got it running. not great but enough to get a timing light. so with the timing light i realized i had to go a notch back with the distributor so i did all the TDC mumbo jumbo and got it in. then i started it and i could hear loud clicking. i looked and my oil light was on. so i shut it off. it seems im getting no oil pressure. so i called my old boss the mechanic and he said that the oil pump gear could of got knocked down ( or whatever meets the distributor gear inside from the pump) so i should see if it did. well i pulled to cover off the engine and i see a timing chain guide sitting on a cam. broken off and sitting there. and i looked and some of the gears that turn my chain and one of them is missing like every second tooth. thats on one set of the gears. i can see two sets of two. and in one set one of the gears is what i said that has teeth missing. ANY HELP PLEASE
