WOW HIDS WAY TO GO!
Hamidanipunk
Car: Nissan Altima Coupe radiant silver 2.5s cvt
i just installed my HIDs today. 8000k. they were lookin dope until i tried starting em up later at night. only ONE works now! is it possible to burn out the bulb that fast or did something disconnect? im so pissed!
bina12834
Car: 06 G35 coupe
do you have the "auto" headlight feature? if you do, dont have your headlights set on "auto" when starting up the car. just leave them on "off" when starting up your car and then turn them to "auto." also, a relay harness will solve this problem, and you can leave them on "auto" all the time. what happens when you leave them on "auto" is that the headlights arent getting enough power through the stock headlight wiring when the car starts up, so only 1 or none of the bulbs will fire up. getting a relay harness will draw power directly from the battery and solve this problem.
Hamidanipunk
relay harness? i have the same kit as u. the super slim xentec HIDs. doesnt that come with a harness?? or am i thinkin ballast? where do i get a harness and how do i install it?
bina12834
Car: 06 G35 coupe
type HID relay harness into ebay and youll see what im talking about.
imdavit
Car: 08' Radiant Silver Altima Coupe 2.5s
i dont have this problem and mine is on auto all the time, so do i have to think about this?
BlackNWhite
Car: 08 Altima Coupe
^Yea... and you should also consider the relay kit incase one of your ballasts frys. The wiring kit will take all the damage and leave your OEM harness untouched.
