Sentientbydesign wrote:Go to autozone or Home Depot/Lowe's and get some heater hose. The likelihood that you have some amazing diameter that they don't have is not likely, especially because the hoses stretch 1/8-1/4 in at that size.
If that doesn't work, get some Quick Steel and roughen up the nibs. Apply the Quick Steel so that is makes the nib large enough for one of the hoses you could find. And Voila! Your problem is solved.
I have Quick Steel holding the nibs on my intake (home made-NO PVC!).
Thanks alot, I googled for Heater Hose and thats basically what I need, it seems like It would be flexible to a certain point.
I will have to go check around tomarrow after work for places that carry heater hose in the diameter I need.. hopefully I can find the right diameter or at least something that doesn't crack and tear from stretching it that bad.
Here are two pictures of the hoses I need.. I pulled these off the car and walked into my Autozone with them and asked for a more flexible alternative instead of the hard pre bent hose similar to it, and the guy basically looked at me funny and said the diameter wasn't one he's seen.
I didn't want to travel 15 miles to hear the same **** from the Pepboys/Advance Auto, so Im going to check out Ace Hardware tomarrow they have a automotive section. I should have a better chance finding some heater hose there. Im going to measure the openings on the intake openings from side to side and see what I get as well.
Modified by MaXimaSE at 8:01 PM 9/12/2007
Modified by MaXimaSE at 8:02 PM 9/12/2007
