Zwicked »
https://forums.nicoclub.com/zwicked-u65277.html
Fri Jan 08, 2010 4:09 am
A lot of issues are caused from the EFI electrical connectors corroding and causing poor connection. Any of the ones with the spring clip are subject to this as they are not very weatherproof to start with, and over time and engine bay heat they crack or completely break. This is the Nemesis of this vehicle. They all need to be pulled and as much corrosion as possible needs be scraped away. Step 2 is to use a high quality contact cleaner. Lastly dielectric grease should be applied to guard against future corrosion.The other issue is these vehicles are about 20 years old, and like any aging car things give out such as injectors, Idle Air Control Valve solenoid, Coil Packs get weak, vacuum hoses crack and leak, etc and generally the engine mechanical simply wears out.Testing components to ensure they are in spec and operational as well as a compression test so you know how healthy the engine is, is an important step.Doing all of the above most often flushes out any issues.I've found this vehicle, in many respects, is easier to work on than most any newer one.
