it's a custome pipe. i will fabricate one in the near future. currently, the charge pipe for my fmic is still using the stock elbow w/ stock bov.emperor_lunchbox wrote:boostsfed, is that a custom piece or can it be purchased somewhere?
look like they overlap the welds, but what i'm planning is a mandrel bend aluminum tube in similar fashion.crxcess wrote:are all those welds butt-welded or is there an overlap? maybe a mandrel bent steel pipe is theway to go or cast aluminum?
Looks like alot of man hours invested in that one.
i'm thinking so as well....i don't know if i will ever put down enough power to put the stock IM out of its efficiency.goofynick6 wrote:Interesting that a setup as nice and modded as that uses the stock IM..
as for right now, the stock pipe run accross the head is already heated quite a bit. maybe wraping it helps.blk90s13 wrote:but wont that make the pipe hot before getting into the intake ? being on top the valve and all ?
i have tried that initially, it's about 1-1/2 foot extra of piping, too long IMO. i think runing the charge pipe like in the picture above would enjoy both world, while not needing a new IM.blk90s13 wrote:i was thinking go out on the side just like a sidemount and route the cold to cross over the intercooler then in infront of the radiator
if you read carefully, it's not my car/motor. what SR? i'm not comprehending.Sil240 wrote:What kinda exhuast manifold are you using??
Mo dont you have a hole there from the SR??
thats not his car so he wojnt know wut kind is the manifoldSil240 wrote:What kinda exhuast manifold are you using??
i agree...i would say 2.5" is the idea sizeKamin wrote:remember guys, velocity is just as important as volume. a 3" charge pipe is HUGE. i dont think most of the people here run turbos big enough to warrant that much airflow.
i'll be making the pipe soon, i'll let you know if it clears the hood or not.about the heat issue, i plan to ceramic coat it + wrap it to minimize the heat from the head.rbsileighty wrote:Might not be a bad idea to have any charge pipe you use cerami-coated to keep it cool (or wrap it)... even the 120 deg version. I'm still want to know if the hood will close with that 120 deg setup...
I might cerami-coat my current setup as I'm not a huge fan of the "bling" factor of my charge pipe... and I'm sure the hot air from the radiator doesn't help keep charge temps cold.
