Would you TRUST your Timing??
cubantunr
No Flaming, the engine is an Sr20det redtop!!! Alright, bought the car a while ago and was told that the timing needed to be done when i took off the valve cover and set it at Top Dead Center everything seemed to be lined up?? the pulleys was set at the yellow mark, and the intake and exaust cams were set at 10 and 12, only prob is that it seems to be a tooth off? here are some pics...lines up with the yellow...Intake is at 10 o lock like it should beand heres the exaust one, seems to be a tooth off...its at 12 o clock like it should be exept the black notch is one over I was wondering if you think it'd be ok to run it like this?? i was told its alright and that when i have it running to just move the distributer/ignition timing till she runs smooth... bottom question isDo you think it'd be ok like this. thanks for the info.
Gabes13
Car: rb20det s13
cubantunr wrote:i was told its alright and that when i have it running to just move the distributer/ignition timing till she runs smooth
SR20s have distributors?
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
What i dont understand is if the exhaust cam is off by a tooth, why is that ok to run?
zip tie the chain in place on the intake came given everything else is lined up 100% and pull the chain off the exhaust cam and rotate it one tooth clockwise. Then chain back on, double check everything. Crank the engine by hand to make sure nothing hits. Then you should be fine.
Assuming you added oil etc, fire it up.
jessetang
Car: 1995 240sx
You need to keep rotating the crank until you see both black teeth. It usually takes couple complete turn form the crank to achieve this.
cubantunr
Friend said that it houldnt hit if its jus a couple or one tooth off, i turned it over, over three times, theres only one black notch i was like wtf. tomo ill check it out...i dont get it, if the timing chain was messed up then when i turn it over now it should hit suthin ut it doesnt i turned it over alot to get to TDC and nothing hit...
Chris28
Car: 92 s13 KA-T
SR20DE's have distributors, SR20DET's have coil packs.
But I know what you meant haha.
ZootedS13
Car: 1990 240sx se
i wouldnt trust it. timing is too precise to second guess.
i would check again for those black marks
Hoffman5982
Car: '95 sr20det 240sx
As safe measure, especially something like this, I would make 100% sure it was right before hand. That's just me though, and Im pretty sure I have slight OCD
OM3GA
OCD is valuable in situations like these.
cubantunr
Alrightim pretty sure ima take it to a tuning shop just to get this safely timed but until then ill try a lil more, i put the car on jacks and took off oil pan and thing behind it so i could see the lower part of timing chain, The car is at TDC with them at 10 & 12 with only one black notch at the top showing and its a tooth off but when i go to look at the ottom timing chain were the gold notch should be theres nothing!!! ahhhhh lol FML
cubantunr
Hahah yea coilpack, thanks for understanding.
