Jacko3 wrote:A car's compression never stays the same as the engine ages. I would think that the compression would have reduced to a reasonable level at 75,000 miles, which makes the supercharger potentially safer for your car, as far as heat egnerated is concerned. The higher the compression ration, the more dangerous power adders are. The less the compression ratio, which can be achieved by rebuilding the engine or by natural wear and tear, the better the power adder will work with the car. This is just my assumption. I could be wrong.
The compression ratio of a motor is not affected by wear. The effective compression might be, but that would be due to ring sealing problems, which is a problem that should be resolved even with a normally aspirated motor. Adding boost will only make the problem worse as the higher pressures will cause more blow-by.
