1sikS13 wrote:i did it on my s13 WC, i got mine from advacned auto parts in the ricer section. they come in a 4 pack with huge pigtails and inline resistors. when you take your hvac apart there are two screw in halogen bulbs that come out and you have to solder the led wires to the circuit board. i thought there was a writeup on here for it.
zerothread?id=174340
found it
and here is one for all the buttons in your cluster
zerothread?id=282768
and another for the s14
zerothread?id=337580
My useful post for the day
WRONG!!! LED bulbs I found require no modification, Simply take out and put back in...
got_chub wrote:here is the red needle kit and clear needles
and day time
being someone that has had them and used them for 2 years i can say they suck and i DONT recommend them to anyone. the only reason i kept them at all was the fact that i could not return the needles to stock once the paint was scraped off.
Two things, one you have those not so awesome lay over faces, and two they're white and the needle kits don't look as good on white faces, black is where it looks best... Just FYI...
*UPDATE*Put blue LED bulbs in gauge cluster, looks pretty good, but def need the glow needles, you can't see the needles too well, I'm hoping the needle kit will help with this and make it look a lot better, tomorrow I'm also ordering a new A/C controler and do the HVAC install guide later on, but I should have the gauge cluster with needles write up by sunday (at the utmost latest). Minus the clock LED cuase the blue looks sweet, but with stock clock lighting looks stupid. Also gonna have cigarette light and possibly window switch...
So check back soon!!!!
