would this z32 rear hubs fits on s13?
solarex
this doesnt seem like a NA z32 rear hubs...
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
JUST TAKE THE SPINDLE/HUB SETUP FROM THE Z32 AND USE IT, IT IS THE SAME AS THE S13
s86d
Car: autocross, backroad racing, and working on 240's
those look exactly like the ones i put on l my s14; however, im not sure on the s13
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
musicsurfman wrote:JUST TAKE THE SPINDLE/HUB SETUP FROM THE Z32 AND USE IT, IT IS THE SAME AS THE S13
except for the fact that they are NOT the same ;)
S14 SE rear hubs bolt on to s13 rear spindles and so do NA 300zx rear hubs (same as s14 rear hubs). Im not sure if the TT zx rear hubs work or not.
-matt
solarex
s86d wrote:those look exactly like the ones i put on l my s14; however, im not sure on the s13
can you confirm this is from a NA z32??
s86d
yes but i do not have pictures I installed them last week and so far tits!
solarex
s86d wrote:yes but i do not have pictures I installed them last week and so far tits!
great! i was affraid it's not from a NA from looking at it's dissimilarity to other NA z32 rear hubs. oh well..live and learn :ylsuper
PROJECTRB240SX
THE WHOLE ENTIRE REAR SUSPENSION ON A Z32 IS THE SAME AS ON THE S13, ITS THE FRONT THAT IS DIFFERENT.
PROJECTRB240SX
AND I KNOW BECAUSE I'M SITTING HERE LOOKING AT THE NISMO CATALOG AND ALL THE REAR PART NUMBERS ARE THE SAME.
Onizuka
but the shock mounts are difforent, 300zx rear spindles are fork type shock mount, and the 240's is not, and it would require very expensive custom shocks. Other then that, yes they are bolt on. Anyways, swapping the whole rear end is about 20x's more complicated then just switching the hubs and re-drilling the stock rotors for 5 lug.
solarex
musicsurfman wrote:THE WHOLE ENTIRE REAR SUSPENSION ON A Z32 IS THE SAME AS ON THE S13, ITS THE FRONT THAT IS DIFFERENT.
thanks music...you rocks:D
Onizuka
solarex wrote:thanks music...you rocks:D
I repeat, it is NOT bolt on. But if you want to pay $2000 for conversion coilovers be my guest.
-matt
PROJECTRB240SX
UMM IS CALLED PRESS OUT THE BUSHINGS ON THE S13 SHOCKS AND PRESS IN THE Z32 BUSHINGS. IF THEY AREN'T THE SAME WHY DOES NISMO USE THE SAME NUMBERS?
solarex
J-Spec Tuner wrote:
sorry JSPEC, props to you also...:ylsuper
solarex
musicsurfman wrote:UMM IS CALLED PRESS OUT THE BUSHINGS ON THE S13 SHOCKS AND PRESS IN THE Z32 BUSHINGS. IF THEY AREN'T THE SAME WHY DOES NISMO USE THE SAME NUMBERS?
that explains itself. it should be interchangeable if they list with the same part #
Onizuka
Dude, *REAR* 300zx suspention, you're talking about the front suspension.
"The 240SX uses a post-style lower shock mount (Left), while the 300ZX twin-turbo, from which we stole our rear uprights, uses a fork style lower mount (right). If these lower mounts are welded to your rear shocks, you'll need to buy new rear shocks to switch to the Z upright."
If you use the 300zx rear sub-frame, you have to get conversion shocks/coilovers.
solarex
it would be quite a hassle and impractical if i do go with the z32 rear spindle, however, swapping the hubs would be sufficent for my purpose.
i do agree with J-Spec Tuner, i would need a fork style struts if the z32's spindle were use.
PROJECTRB240SX
ESSENTIALLY THEY ARE THE SAME BECAUSE THE ZX USES A BUSHING TO SUPPLIMENT THE LOWER SHOCK MOUNTING. WHATEVER BELIEVE ME OR NOT THEY ARE THE SAME PART NUMBERS JUST THE 300ZX SHOCKS USE A BUSHING. DO WHAT YOU WANT.
Onizuka
PROJECTRB240SX
SO USE A 300ZX SHOCK, AND I REPEAT NISMO USES THE SAME PART NUMBER, AND IS THAT TURBO ONLY OR NA TOO?
NOW WHY CAN'T YOU BUY A PILLOW BALL MOUNT AND ROTATE THE SHOCK?
Onizuka
i give up, if you dont belive the pictures im showing you then its pointless for me to continue to argue. 300zx and 240sx shocks have difforent mounts on both ends of the shock.
PROJECTRB240SX
I DO BELIEVE YOU, I HAVE JUST SEEN THE SUBFRAME PHYSICALLY BOLTED IN AND HOOKED UP TO A S13. AND I DON'T REMEBER HOW THEY GOT IT TO FIT BUT IT WASN'T CUSTOM COILOVERS.
PROJECTRB240SX
OHH WELL THERE YOU GOT A MORE SOLID ANSWER. AND NISMO USES THE SAME SPINDLE NUMBER SO I'M SURE THE HUBS SHOULD BOLT UP.
