would this work?
s14tan
Car: 95 ZenKi SE w/ S14 SR GT28r and bolt ons
how hard would it be to fit 10" wide fno1r-c's in the front on a S14?..if possible.I just would like to know...
Im prepared...
boznuttz
Car: MS13
Offsets? and what suspension?
Stock or pulled/ rolled fenders?
What size tires are you looking at?
A good way to find out some of these q's if you aren't sure yourself is to check some other threads here in which members post their setups.
s14tan
I didn't realize all that would be a factor.I'm personally not really good with off sets and sizingI just heard that it would be really difficult to do or near impossible to fit a 10 in in the front.
whats specs would be needed to make it work?
adrianfromthecastle
Car: 1992 Nissan 240sx
Ive seen it done before....
hell, I've seen it done on an s13 before too...
I dont remember exactly offset and tires specs used, but I can tell you straight out that a +25 or +15 aint gonna cut it
s14tan
Why wouldn't a +12 or +25 not work?
Modified by s14tan at 11:54 AM 12/12/2007
adrianfromthecastle
s14tan wrote:Why wouldn't a +12 or +25 not work?
it'll rub on front suspension...
my buddy has +15 on a 9.5" and his rubbed on the coilovers.
s14tan
oOoOoOOo..
What if you don't have coilovers like me?
adrianfromthecastle
s14tan wrote:oOoOoOOo..
hmmm good question...
you know what's wierd, coilover springs have a smaller diameter than lowering springs, but I've heard that people have better clearance with lowering springs than coilovers...
s14tan
Hmmm I wanna try it and find out but its a costly experiment....
what other wheel do you know of would have the concave look besides TE37's?
nismofly
Car: 89 Nissan 240SX Hatch
the +12's work up front on an s14, not an s13
im not sure however how much tire youd be able to fit before i rubbed
s14tan
What tire size should the front be?
adrianfromthecastle
nismofly wrote:the +12's work up front on an s14, not an s13
s14tan
We Demand Proof!!! lol
94_240sx
Car: 94_240SX
adrians_s13 wrote:you know what's wierd, coilover springs have a smaller diameter than lowering springs, but I've heard that people have better clearance with lowering springs than coilovers...
Don't forget spring seat on spring perch that goes above the tire.
yokota180sx
Car: 1997 Stagea RS4, r34 front
its because most lower springs, becuase on the stock shock sit abouve the tirecoilovers moreoften than not are right next to the tire.
to answer your qwithout at 30mm fronts, you cant do it.
adrians_s13 wrote:hmmm good question...
s14tan
