Would This Ruin The Odometer?
pcrcool
Car: nissan coupe
Im getting a 2011 altima coupe 2011 and will be swapping out the 17" standard wheels with 19" rims and low profile tires (30mm-40mm). Will I have to adjust the odometer?
The dealership told me most likely I will not have to alter the suspension, so will the odometer be fine?
Thanks
wade001
Car: '09 Nissan Altima Coupe S 2.5 M/T
look at the wheel and suspension section. you cant adjust the odometer.
pcrcool
Car: nissan coupe
wade001 wrote:look at the wheel and suspension section. you cant adjust the odometer.
Well i thought the dealership could reset it or make it match the wheel when you do stuff like that? idk
wade001
nope, cant be done, all you have to do is make sure the outside diameter of the tire is the same as factory or real close.
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
You CAN have the odo adjusted... you DONT NEED TO
The entire diameter of the wheel/tire combo should be very close to the stock combo, it may throw off rhe speedo 4% in either direction...
Check the tires and rims section... I have 19s with 245/40/19s on them, and ive had 245/35/19s on them... keep it as close to spec as possible... 245 40 19 is the correct tire for a 19x8.5 wheel
bundy26
Car: 2011 Buick Regal turbo
pcrcool
Car: nissan coupe
LongBeachCoupe wrote:You CAN have the odo adjusted... you DONT NEED TO
So what do you think about this combo then: Its 235/35R19, so that way its not to thick and not to thin, i think. and the 235mm keeps it closer to factory spec which is 215, or maby im wrong all about my methodology
http://www.directbuytire.com/product-p/14am9afa.htm
http://www.wheelstudio.com/view-wheel/r ... hicle-5103
czonin
Car: White 09 Altima Coupe 2.5S
245/35/19 is the size your gonna want. And be careful with cheap tires like that. I've heard stories of people with cheap ones that have just skidded into things when trying to make a turn. Research the tires a little on Google for reviews.
pcrcool
Car: nissan coupe
czonin wrote:245/35/19 is the size your gonna want. And be careful with cheap tires like that. I've heard stories of people with cheap ones that have just skidded into things when trying to make a turn. Research the tires a little on Google for reviews.
WAit but whats wrong with 215mm tires? Because my rims are 19x8.5, so 215mm tires = 8.5 inches, so 245's would be to wide right?
Thanks
LongBeachCoupe
2005 Lexus RX
Pcr, please read more and post less!
Theres a wealth of information in the first few STICKY threads in the wheel section.
pcrcool
Car: nissan coupe
LongBeachCoupe wrote:Pcr, please read more and post less!
Hey,
Alrighty, I apologize, I am all done posting questions and asking anymore. I just love this forum, and am excited to get my new coupe so Im asking so much to make it the perfect purchase. But From here on out Im done until I get my car, then I can make a post to show it off, haha. But yeah, alright cya.
Thanks
......pcrcool
One of the most important things to learn is how to PROPERLY size tires. I can almost do it in my head.
90% of people have no clue what the numbers on a tire mean, and how they relate to each other (and the car).
Don't cheap out on tires. If you can't afford good quality wheels and tires, you don't need them - stick with stock or a smaller diameter. Fake-ballin' looks gay from a mile off.
(Honestly, I think 19's on a AC is overkill, but that's just me).
