auditech10 wrote:The fronts should fit perfectly with 245/35 tires and the rears should fit. They are really only 33mm more towards the shock which is about inch and a quarter. You should be more than fine with even a 275 rear but to be on the safe side a 265 rear tire would be fine.
Okay-y-y-y ... if you say so, but I'd love to see some pictures of this not contacting!
By the way, I count it as (10-7.5)/2 = 1.25". This is 31.75mm, plus the extra 5mm larger offset for a total of 35.75 mm ... about 1.41 inches! But that is only 2.75mm more, I suppose!
Anyway, in the past, I have tried to see what is possible on my 2003 M45, and to me, a 1.4" difference in wheel location seemed that it would touch the suspension. Particularly with the tires that you would need to put onto a 10" wheel!
If it works out, I will stand corrected!
Z
