Postby
TwoForDee »
https://forums.nicoclub.com/twofordee-u165338.htmlSun Aug 01, 2010 9:14 pm
I was looking into 5 lug conversions for my 240sx and I saw one company sells a pair but they also act as a 50mm spacer, could anyone show me a picture of a 240 with 50 mm spacers? Thanks
Postby
simmode1 »
https://forums.nicoclub.com/simmode1-u73804.htmlSun Aug 01, 2010 9:38 pm
I agree with Chris. The point is to do this right the first time and you wouldn't need spacers. There are enough 4 lug wheels available to seriously consider keeping the stock setup. See my sig if you want more 4 lug options that would look good on a 240.
But going 5 lug is pretty damned cheap and easy if you wanna do it.
The only way I'd use a 5 lug adapter with a ginormous 50mm spacer like what you're talking about is if it converted my car to a Chevy lug pattern. Then, in that case, you could run old school OEM Corvette wheels... which were like 17x9 & 17x11...
Postby
Metal Angel »
https://forums.nicoclub.com/metal-angel-u132925.htmlMon Aug 02, 2010 10:54 am
oh... i just realised... you are looking at a 4 lug to five lug spacer conversion... say no! run the other way! You wanna get an actual hub swap, not just a wheel spacer that goes from 4 lug to 5 lug.
Postby
Seanzyyy »
https://forums.nicoclub.com/seanzyyy-u135160.htmlMon Aug 02, 2010 3:20 pm
ILoveMyRHS13 wrote:
Proper 5 lug or go home.
debatable.
5 lug has a greater variety,
but there are enough choices for 4 lug for people to stay 4 lug.
50mm spacers seems a bit overkill imo.
i have 25mm spacers,
if that was doubled it would like a bit odd.
thinking about how it would look makes me want to say "orale esse!"
Postby
Spring Break '92 »
https://forums.nicoclub.com/spring-break-92-u165516.htmlTue Aug 03, 2010 1:25 am
Powered by Max offers a 15mm spacer set with long studs installed and 3/5/7mm spacers that can be added on to them individually or all at once making a 30mm total as a set, or you can buy just the 15mm spacers. I have a set of Enkei RP01's that I got for cheap and was thinking about how they would look with the 15mm spacers. They are +32 and +38.
