Would these work
burnout 180
Car: 1990 s13 180sx ca18det
Wiil these injectors work on a ca18det.http://cgi.ebay.com/ebaymotors...QrdZ1
Or would i need some other stuff for them too fit.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Yeah, but the fuel rail ports may need to be machined slightly bigger. I had it done.... cost me $10.
burnout 180
which injectors would be a direct fit because i can't get anything machined.
burnout 180
would DSM injectors be a direct fit?what are all the injectors that would be a direct fit?I heard that skyline injectors are a direct fit also but what year.
mikesim
DSM injectors are a direct fit if u use the o-ring from your stock injectors for the fuel rail.
boost_boy
burnout 180 wrote:Wiil these injectors work on a ca18det.http://cgi.ebay.com/ebaymotors...QrdZ1
I use MSD injectors which is very similar to these Delphi units and I never machined my fuel rails nor my customers. Like Mikesim said, the trick is in the O-ring.
Dee
nismoplsr
It must depend on the manufacturer. I bought the Lucas brand "DSM" injectors and i had to drill out the fuel rail slightly. It was not the difference in the O-ring the injector was physically to big to fit even with no O-ring.
burnout 180
This means that after market DSM injectors are a direct fit to right?
c-rad
nismoplsr wrote:It must depend on the manufacturer. I bought the Lucas brand "DSM" injectors and i had to drill out the fuel rail slightly. It was not the difference in the O-ring the injector was physically to big to fit even with no O-ring.
Exactly. Lucas, RC, Delphi and PTE all use the Delphi body. So any of those will require the rail to be machined.
Just out of curiosity, why is not possible to have it machined? Take them the rail and the injector (with o-ring) and say, "Make it fit".
boost_boy
Hint-Hint "MSD"= no headache/plug and play. Even my 95lb/hr injectors came ready to plug and play.
Dee
burnout 180
Because I'm lazy and just rather get something that can directly fit in instead of have to go through getting my rail machined.
So I guess MSD DSM injectors is what i should get. Is ebay the place to get these or is their a better place to get them from. Also 72lbs = 750cc right?
burnout 180
I searched MSD Injectors on ebay and got these as results
http://cgi.ebay.com/ebaymotors...wItem
Which one is the right one to get?
c-rad
burnout 180 wrote:I searched MSD Injectors on ebay and got these as results
Neither as both use Delphi bodies. MSD refers to the type of electrical connector, not the body itself. If you are looking for a direct fit, look for a Denso bodied injector.
burnout 180
None of the denso injectors are in good condition on ebay. So i decided to check out autozone and they have msd injectors.
Here is the one i was looking at will this work?
http://autozone.com/servlet/Ui...EtrueAlso 72lb is what in terms of cc
c-rad
burnout 180 wrote:None of the denso injectors are in good condition on ebay. So i decided to check out autozone and they have msd injectors.
Honestly, those look just like the Delphi body injectors. Unless they are specifically Denso, I wouldn't count on them fitting perfectly. Companies like HKS, Sard, etc all use the Denso bodies.
