It should be OK, but definitely requires a test fitting.GM991 wrote:To close in your epinion?
All I'm really looking for is another set of 17x7.5 30 offset for my Q So I can run winter tires on my stock Q wheels.Its a ***** trying to find some that don't cost $700-and upI don't care if they are nissan....I can't find crap!!!
No thanksSee what I'm trying to do is.My stock Q rims are pretty beat (from origanal owner)So what I want to do is the tires are less than a year old.So I want to get a nice set of 17" rims that the 225/50-17 I have will go on for summer tires and them BUY winter tires and put them on the stock wheels for winter.bullittandy wrote:I have a set of 16" turbines if interested?
For the tire sizes you want, yes.GM991 wrote:Found a set of these on e-bayWould these fit??
Size: 17" x 7 1/2" offset 30 (fronts)
17" x 8" offset 33 (rears)
Bolt Pattern: 5x4.5 or 5x114.3
I would want to put 225/50-17 on them?
LOLFunny..I just don't have the money right now to buy new tires when those are new.I have to spend the money on snows right now..maxnix wrote:For the tire sizes you want, yes.
Are there any good tires in that size?
cool thanks for the info.I will have to go chace them on e-bay..maxnix wrote:Profile should be so similar in combination with the high shoulder, I bet you can't tell. 3 lbs. of difference in pressure should be more detectable.
Few normal drivers can detect a 3 psi difference in normal driving.
Forgot to metion the wheels are ASA brandGM991 wrote:found some others what about this set-up
225-50-17 FRONTS , 225-55-17 REARS...BLIZZAKS from a 2004 G35 SPORT EDITION 6 speed.
Modified by GM991 at 3:19 PM 2/19/2007
point taken thanksBut if they fit that car would they work on mine?? with the offset and all?/maxnix wrote:I would have a lot more confidence in OEM Nissan than ASA.
All used wheels should be checked for tolerances before purchases. Q45tech had to reject about 50% of the ones he purchased or wanted to purchase.
Will the different size tires from the back and the front set off my ABS light??Would not set of the light on the G because the car/ABS is set up for bigger/wider tire in the backGM991 wrote:found some others what about this set-up
