Would these wheel's offset work with my V?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
reyes1212
Car: '07 Nissan Versa Super Black
blindsnyper
Car: 2007 versa
i think you should be fine (mine are 42 so...). but if not just use a small spacer. those are sexy btw
reyes1212
I've got some acorn lug nuts that I hope sit into the rim well...lol
bucksnort
Car: Versa S
You'll need a 5mm spacer on the front to clear the calipers maybe. At least that is what I needed when I put G20 wheels on my Versa. Maybe those wheels will clear
reyes1212
bucksnort wrote:You'll need a 5mm spacer on the front to clear the calipers maybe. At least that is what I needed when I put G20 wheels on my Versa. Maybe those wheels will clear
What offset are they?I'm just concerned I wouldn't be able to tighten them on or something because the acorn lug nuts wouldn't work and also about the offset. I'm clueless in this area.
feloniousmonk
"These wheels are made from solid gold."
Is he trying to not sell them? Gold is the worst material for wheels... it's a soft metal, about as soft as lead. I know it's a figure of speech, but it sounds stupid.
reyes1212
LMAO didnt catch that
blindsnyper
Car: 2007 versa
just get some 5mm spacers and tuner lug nuts off ebay and you will be set, im 99% sure
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
Those are nice wheels. You might be okay on the offset but I can't say for sure. The only way to really tell is to try them out and make sure they clear the calipers in the front.
M2Motoring
Car: 2007 Nissan Versa, 2005 Scion xB, 2002 Nissan Xterra, 1990 Mazda Miata, 1998 Mercedes Benz Slk230
Hi I have a set of barely used tws cataluna wheels 18x7 +40 from my sema project a while back. $300 plus shipping for the set its just sitting in my garage lol. it's in great condition used for sema and that was it.
Return to “Versa Technical Discussions”
