AlexN09 »
https://forums.nicoclub.com/alexn09-u185794.html
Sun Sep 01, 2013 9:25 am
I'm no wheel fitment expert BUT.. My understanding is this. That wheel is 9" wide. The stock wheel is 7.5 inches wide. If the offsets were identical then the new wheel would be .75" wider on either side of the hub. Meaning it would be .75" closer to the fender as well as the inner wheel well. Now the offset increased positively by 2mm so it actually sinks in away from the fender 2mm. So the total change would be .75" less 2mm from the outer fender. Hence why I said a little less than three quarter inches further out.
Please correct me if I'm wrong.
