TgduMg wrote:The specs for the 99-01 Q45t wheels are identical to the front 350Z 17 inch wheels, 17x7.5+30mm. The base (F)Y33 wheels are 7 inches wide with an offset of +40mm, so installing the 17x8+33 on the rear should present no problems. It would be nice if all four of your wheels were 8 inches wide though. When the time comes to replace your rubber, I'd go with 235/50's on all fours.
Danisiti 1
Danisiti 1
I just bolted on 18X8 with a 30mm offset with 255/45/18 on my 97 Q. Rears fit fine and the front 255's would also have fit except that my right front strut is bent and that tire rubbed. I bought 245/45's for the front.I went with 255/45 to improve the ride as this tire is slightly taller than the 245/45. But it didn't work.
