s13sr20detsilviastityper »
https://forums.nicoclub.com/s13sr20detsilviastityper-u48984.html
Thu Oct 26, 2006 3:26 pm
ok never mind the title
car doesnt idle well (rough) and misfires at low rpms mostly
i have checked spark , fuel, etcfully advancing the timign helps, but thats not the proper way to fix this
ecu throws code 34 for knock sensor, the incoming wire off it was soldered to a ground i believe with a resistor inbetween? so i may wire that outside the harness direct into the ECU
i am going to change the spark plugs this weekend.. they didnt look too healthy
any other ideas?
Modified by s13sr20detsilviastityper at 11:47 PM 10/26/2006
