Clatch »
https://forums.nicoclub.com/clatch-u17761.html
Wed Jan 11, 2006 3:36 pm
I just had the Michelin Pilot Exalto A/S put on with an alignment for $343. The 55 series side wall with a V rating was $473, so I was happy to go with the stock 205/60/15. I took it through my "test track" about 2 minutes ago. PHENOMINAL TIRE! I actually hit the limit in it for the first time; as my stock 240 sits I can push full throttle through apex's previously undoable on the Traction T/A's. I hit one turn in fourth where full throttle I would start to hear some bitching from the T/A's and signs that the back end was starting to slip. Now I was absolutely stable in fourth so I downshifted and eased it back into full throttle in the same turn and had no problems. So I went back at it in third, got to about 5500 rpm's at apex full throttle and the tire was unbelievably solid; the car was too slow to spin the engine any faster, too stock suspension, and open diff to be able to the corner any faster and/or break loose. I got to 6000 rpm’s, (end of the maximum power in the KA) before the end of the turn, put it in fourth and was blown away that the tire did it like no problem I was practically going as fast as I could squeeze out of the 240 and the tire wanted more! I guess you could say it outclassed the car. The KDW’s would have been overkill.
The only cons I have about this tire is 20-30 mph and under they feel more sloppy and more luxurious than the T/A’s. It feels like they are under inflated for some reason, something I think the 205/55/15’s might have taken care of. However, this is just feel, 20-30 in under they SMOKE the T/A’s in traction. Needless to say, I’m very very happy.
