leesredgt wrote:i dont the exact amount left but the fuel light is on,i was trying to let it run out so i could put new better fuel into it.
terrible idea.best way to get rid of "old fuel" is to dillute it with the proper, new fuel.
all you are doing by draining your gas tank after it has sat with 87 is putting gas that has sat and settled (probably not stable anymore) into an engine not meant for 87 octane. On top of that, draining the tank that has sat with bad gas in it, you are gathering all of the gunk and sludge that has gathered over the years at the bottom of your gas tank and sending it through your lines.
I'd recommend you put 93 octane (highest around here) with a thing of fuel stabilizer in it for starters. Drive that around until it is done without going into boost much, and then repeat the process for 2-3 more tanks.
Getting below 1/4 of a tank of gas in these old cars/gas tanks is a bad idea.
