RAP »
https://forums.nicoclub.com/rap-u76868.html
Fri Feb 29, 2008 3:23 am
Quote from Rex above:Removing/disabling the ABS has both short term and long term costs, just weigh the advantages (to you) and disadvantages (to you and the next owner) before doing so.
How so pray tell?
I did not remove the ABS in my Acura. It just went bad and I have not repaired it so far. Probably not gonna. Not so much the cost, but rather it's really not useful for me.
I will not remove the unit from the car since the wiring is bundled with other wires as part of the harness and I have no desire to disturb any of those wires, or any wires, on any modern cars unless absolutely necessary.
The tubing for the brakes/fluids goes through the ABS system and works quiet well the way it is and will not fail because of that.
Now for the hot driver above. The legal speed limit, since legal and ABS is mentioned, is probably no more than 60 mph in congested areas and possibly less. There is a slow traffic lane for the pokes and that is usually on the right. So no one is required to speed. Duh. I don't find it difficult to drive slower in congested areas if I so desire. Plus from long time observation I can assure ya'll that I will arrive at destination about just as fast as any hot rodder. My observation, and, I drive most every day as required for doing MY JOB.
On the one hand it's "I have ABS so I can speed in excess of the legal limit"? ? ? or, on the other "it's illegal to not fix a broken ABS"? ? ? So what the story here?
I am well aware of the ABS, MUCHO Airbags, three point harness/seat belts, etc that are part of the insurance questionnaire when buying coverage. I am also aware that I AM responsible for my, and the safety of others, when operating my vehicles. SLOW is the way to GO for the most part.
The single greatest improvement to vehicle brakes has been the vaccume booster to assist mechanical brakes IMO. Everything since then has not done much for stopping the vehicle except disc brakes. An improvement also.
Not much success in improving the mental process though, unless one is so inclined.
Jack
