masticatingcow »
https://forums.nicoclub.com/masticatingcow-u11112.html
Thu Mar 17, 2005 2:21 pm
If it's the same boot I'm thinking of, looking down, it's below and to the right of the brake cylinder. It's super easy to get through there, and the wire will pop out just above the fusebox in the driver's footwell. From there, it's an easy extention across the steering column and into the back of the center console. From there, you can route your switch to anyplace in the cabin. Good luck!
