well it depends on what ur looking for, a new engine would obviously make ur car last much longer, however so would a new sr20, if u want to stay NA and want more power than a KA, then obviously the qr is the way to go, yes it would be costly, but im sure u could find a wrecked altima or spec v with the qr25de in it for a decent price. the KA (depending on year) has roughly 155hp at the crank and 153ft bls of torque and has an iron block (stronger block, much heavier), the QR25DE has 175hp and 180ft lbs of tq, and the SR20DET (depending on year, im assuming ur getting one out of an s13?) this comes with (correct me if im wrong) about 215hp, and this obviously has the turbo (make sure the turbo is working perfectly before dummping ur money into buying the sr20) and doesnt have quite the torque of either motor (about 140ft lbs), obviously all of hte engines would fit, im pretty sure the KA will be the cheapest, then the sr20, and probably the most expensive (cause of hte newness of hte engine) will be the QR. hope i was some help, someone correct me if u find anything wrong in here, but im pretty sure this info is correct, good luck and nice plan!!blackaltima wrote:Swapping would be costly. How much power would I get by putting in a qr25 to my 2k? How much would I spend to get that power? For less money, I could gain more power by modifying the ka24de. Now, to swap it w/ a sr20det........
amen, couldnt hace said it better myselfCold_Zero wrote:It really depends on what you want to do with your Altima. I would have a couple of concerns for swapping engines into a second generation Altima.
First you would need to check to see if the QR25DE or the transversally mounted SR20DE(T) (from a Bluebird or 200SX) would mount into a second generation Altima with relative ease. If the project is going to be a pain and cost lots of money, your money and time will probably be better spent buying a new/different car that has better capabilities.
Second, if you decide to go naturally aspirated and build up the motor, I would choose the QR motor. Obviously the QR motor is 13 percent lighter than the SR20DE engine and 20 percent lighter than the KA24DE engine. The QR has a good power to weight ratio. It also offers the most torque of the three naturally aspirated versions of these engines.
Third, if you plan on introducing forced induction to the engine, I would steer clear of the QR motor because of its open deck block design. You could run low amounts of boost and get by. But I have a hesitation of introducing forced induction to an engine that not initially designed for it. The question is not if you can boost an engine, its how long will you be able to boost it. The QR motor lacks strong internal parts that allow the engine to withstand prolonged boosting like the SR20. The amount of money you will spend strengthen the internals of the QR motor may really be better spent on other performance modifications to your car. The KA motor doesn’t have the strongest internals compared to the SR20 but people have been adding turbo kits to this engine more than the QR25DE.
Lastly, I would think that the SR and KA motors have more aftermarket performance parts than the QR currently does. If Nissan keeps using the QR motor, this will change, as the QR will be the workhorse for the midsize and economy classes for Nissan.
The old adage goes, “With the right amount of money, almost anything is possible.”
well bolting up the sr20 to the stock KA transmission wont be EXTREMELY hard, but a qr swap would defintely give u some trouble, for easyness factor honestly, get a new sr20det and it should easily bolt up to ur stock KA transmission00_Altima MD wrote:well that was actually going to be one of my questions was whether or not i could just bolt in the engine or not
nlzmo400r wrote:i think the sr20 would probably be one of hte cheapest and easiet swaps out there, in the japanese bluebird (granted it has AWD), the sr20 is in there, htey mount rite up on the altmas, however new mortor mounts are needed cuz the sr20 sits a bit higher on stock KA motor mounts
im telling u, an sr20 into a oo altima is not hard to do, its damn near the same as putting the sr into a 240, the japanese altimas (bluebird) came stock with the sr, so i KNOW they fit, and yes they can be put on stock motor mounts, seen it done, personally i would just pay the extra money and get the correct mounts, but either way, it will fit, and ur only problem will be the transmission, as far as engine tho, the biggest problem is wiring, however there are plenty of books with this info in them, but trust me lifeofshadoze, ive seen it done, without much cutting of hte engine bay, sure itll cost money, but wht doesntlifeofshadoze wrote:uh, no lol. thats actually completely wrong. Its one of the most difficult, and requires MORE custom fabrication than a k20 in a hb. They dont mount rite up, n i dont know where u heard this from but please, let your sources know this.
good point, if u had an engine with NO aftermarket support, or that had like an aluminum head and a plastic block, then u got a reason to swap!!. good luck dudeCold_Zero wrote:The KA24DE has plenty of aftermarket support. I don’t think you can go wrong with building up that engine. Even though a SR20DE or T would be great, I don’t think that it’s worth the money if you have fabricate things to install it. Not "worth" it when you have such a capable bro engine like the KA24DE.
