sims »
https://forums.nicoclub.com/sims-u3780.html
Thu May 01, 2003 9:08 am
Ok, I did a search couldn’t find, if there has already been a thread like this, please just post a link to it.
Ill try to be as specific as possible. Ok, what I want to know is, here is a list of parts; I want to know if this is everything I would need on a SR (assuming its in excellent condition, all fluids spark plugs, etc replaced) would be safe to run at 14 PSI on 91 octane pump gas, I want to check and make sure everything looks good and I’m not forgetting any parts, or adding anything I wouldn’t need.
The car will be used for auto-x road racing, and drag racing, all on a pretty regular basis.I added the prices because the parts aren’t yet decided, I just picked parts I’m thinking of right now, so just assume it’s any part in that price range.
APEX'i Power Intake kit $130
Apexi Dual N1 Cat-Back $499
Blitz 3" downpipe $180
Walbro 255 lt/hr Pump $120
HKS SSQV BOV Kit w/ hot pipe $350 (200 for just the BOV)
HKS Type-S FMIC $865
Greedy IC hot pipe $99
Nismo engine/transmission mounts 270
ACT street/strip clutch kit with TODA flywheel $700ish
HKS rocker arm stoppers $90
Apexi S-AFC $345
Greddy Profec B $300ish
Greddy turbo timer $90
The car will be for the most part a daily driver, I know I could get away with not upgrading some of these parts, but I want it to be reliable. What about an aftermarket Koyo radiator or a Dual 12" Electric Fan, would that be needed at this point? Or at least beneficial? I don’t want to waste money on something I don’t need, but I don’t want overheating issues either. and then same question, just replace that other stuff with aftermarket oil pan :P
What about head gaskets? I know some people have gone to like 20 PSI without blowing them, but clearly that’s not common, at what point do they start becoming an issue? Should I start to worry about then at 14 PSI, or wait until after a T28 upgrade
Oh, last questionMy “goal” would be eventually to get to around 400RWHP, other then the clutch, would the parts mentioned above withstand that kind of power, assuming the rest of my engine could was upgraded to support it?
sorry about the long post, but i figure, might aswell get all the questions out in one thread.
