Would I30T BBS wheels fit the J30? What is the stock J30 wheel offset?
GeoFX
Car: 1997 Infiniti J30, 2003 Infiniti QX4
What is the wheel offset for the stock 15 x 6.5" J30 wheels? I've read anywhere from +35 to +40 but want to make sure I got a good deal on the '96-'97 I30T BBS wheels and they have are 15 x 6.5" with a +45mm offset.
Will these fit ok in the J30 or do I run a risk of the wheels rubbing on the suspension since it may be more tucked in (with the extra 5mm of offset)?
Thanks!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Youll be fine with the I30 wheels.
NY94J30
Car: 2000 Q45 AE
GeoFX wrote:What is the wheel offset for the stock 15 x 6.5" J30 wheels? I've read anywhere from +35 to +40 but want to make sure I got a good deal on the '96-'97 I30T BBS wheels and they have are 15 x 6.5" with a +45mm offset.
Thanks!
I have a set of T wheels I will sell to you for say $50 plus actual shipping, if you just want a mesh style with a rwd offset.
colincliff2
i have the 16" wheels from my 2000 I30, the offset is 45mm too, i'm gonna try them this weekend.
GeoFX
Well, I bought the 15" BBS I30T wheels and will try them on next week. If they don't fit, I can return them.
NY94J30, I'm definately interested in your wheels if they don't work out.
I've read a quote here stating that any Infiniti wheel should fit any other Infiniti irregardless of year or model. While I agree that the bolt pattern is still the same that statement seems way too vague for me considering that the new G35 wheels are staggered and are wider than our J30 of 10 years ago. Dunno...
An actual offset measurement of the stock J30 wheels would be beneficial as what I read indicates it's ET="H," which can be anywhere from +35, +40, or +45mm.
Assuming that the wheel widths between the stock J30 and I30T are the same (from what I know they're 15 x 6.5"), a potential deviation of +10mm offset shouldn't be THAT big of a deal, right? The stock front strut and brake clearance is bigger than that I would hope...
Any thoughts?
Here's a pic of the wheels...
Modified by GeoFX at 6:34 PM 4/7/2007
GeoFX
In case anybody is interested NissanNews states that the stock wheel specs are 6.5JJ x 15 with a +40mm offset. Don't think the +5mm offset of the I30t BBS wheels should be an issue anymore...
Modified by GeoFX at 10:12 PM 4/7/2007
mako17
Car: 1994 J30
Do you still have original wheels to fit J30 for sale?
RZAA36
Car: 1993 J30
mako17 wrote:Do you still have original wheels to fit J30 for sale?
I HAVE THEM FOR SALE, 50 BUCKS PLUS SHIPPING YOU CAN HAVE THEM!!!
StevieRaySTL
Car: 1990 Infiniti Q45 w/ Nico ECU
1993 Infiniti J30 w/ x-flow
1997 Toyota Landcruiser
-- OP, post up a pic when you get 'em on, I'm interested to see how they look.
GeoFX wrote: the new G35 wheels are staggered and are wider than our J30 of 10 years ago. Dunno...
-- Mine aren't the sport pkg wheels, but they are 17s off an 04 G35, they bolted right up, no spacer or rub.
GeoFX
StevieRaySTL wrote:-- OP, post up a pic when you get 'em on, I'm interested to see how they look.
Here it is. Pretty nice, huh?
StevieRaySTL
-- Looking good. It does take a trained eye to differentiate those from the touring rims though. Thanx for the pic!
gr8scott72
Car: 1994 Infiniti J30t
Agreed, I had to click on the thumbnail to be able to tell.
StevieRaySTL wrote:It does take a trained eye to differentiate those from the touring rims though.
J30winterbeater
Car: Infiniti j30
StevieraySTL what size tire do you run on your g35 rims?
