First remove the 6 bolts that hold the 3 tabs on, holding the center housing to the turbine housing. Spray the seal where it rotates with PB blaster, let the turbo sit compressor down so the PB blaster forms a puddle ring around where the center housing and turbine housing mate up. After it sits for a night like that, put the turbine flange in a bench vise (TIGHTLY) and hit the compressor outlet with a mallet in the direction you are trying to clock it. Clocking it trying to use a wrench wont work, the wrench will just flex. If the rubber mallet doesnt work, just try a peice of wood and a sledgehammer. Once again, this will only work if the turbine side is firmly held by a bench vice thats going nowhere when the compressor housing is struck.Liquid_Neon wrote:I worked on it a while back with a torch and a big wrench bolted to the center piece with an old coolant bolt. I used it for quite a while after this, so i didn't hurt it in case anyone's wondering.
Ill give it another go with pb blaster... but still a pain in my a**.
Liquid_Neon wrote: my exhaust was 150% fubar.
Good question. OP: Removing the bolts as I mentioned above is for clocking the compressor housing to the CHRA, the snap ring would clock the turbine housing and the CHRA.jynxtrix wrote:Has anyone thought about just getting the snap ring pliers out and taking the the damn snap ring out long enough to clock it CORRECTLY? Maybe I'm missing something here, but I've already rebuilt my turbo, and with that snap ring out (not hard if you pay 15.99 at napa for a set with an angled nose, and even cheaper if you clean them and take them back when finished) it will turn just fine. In 15 years of working on my own cars I have never had to use a hammer to adjust ANYTHING, if If it was being done correctly. Just food for thought.
