would anyone be interested in a pair of rebuilt VH45 siamese heads?
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
defrag010
they are the ones that I used to take all of the pictures in my big thread. I don't have a use for them right now, and I am having to downsize a bunch of my motor stuff because the new house I moved into has a smaller garage.They are complete with cams, have been cleaned, surfaced, valve job done, new seals, and the springs have been shimmed .060" over stock.
Would anyone be interested in them?
Raxephon
Car: '04 RX8...for the moment...
What kind of seals were the old ones replaced with?
I may be interested depending on price...
What purpose does shimming the springs serve?
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
I would think it increases the spring preload, closing the valves faster/harder and generally just reducing valvebounce, marginally increasing the safe redline of the engine.
defrag010
Shims increase the spring pressure, which in turn allows you to safely rev the engine higher without valve float or allow you to run a larger lift/steeper ramp profile camshaft.
The new seals are metal clad style viton.
I was thinking around 300 + shipping??
slshearer
Car: 1990 Q45 Silver/Blue Interior, 2nd owner since 1992, 18" Premium Wheels, 245/45/zr18 Tires, Blue Tok
Will these heads fit a 1990 Q45? Would there be any modifications or would they be a bolt on?
[email protected]
Raxephon
Bolt on, no mods needed.
slshearer
Does anyone have a contact info for the defrag010, the email address is not working for them.
I need a set of heads for a 1990 Q45, I saw your information on the heads and would like to know if they can work with my stock engine. Let ,me know your thoughts and are they available
ThanksStewart678-725-9566
defrag010
Didn't see this thread. The heads aren't stock anymore because I was keeping them stock so I could figure out a drop-in valvetrain. Now that I have finished that, I just started cutting into them hardcore this wee.., so when I'm finished they will have a serious valvetrain that will be able to handle any cam and any rpm you can throw at it.
slshearer
am looking for a set of heads with good valves and seals for my engine, please let me know if you have something which I can use on my 90 Q45, Thanks
vman88
Car: 1996 q45
do you still have them and if so how much
defrag010
no, read two posts above yours
Return to “VH45DE / VK45DE / VK56DE Forum”
