thanks, will have to try this when I get back to the Statesanach wrote:I have my Samsung Galaxy Note 3 connected via bluetooth for phone functions & to play audio. It works just fine. Plugging it in to the usb, on the other hand, doesn't really work.
...or head over to XDA and see if a custom ROM based off Android L (5.0) is available for your current Android device. That's how I'm heading when one is released for my Note 3....oops sorry...got carried away...wrong forumwideopn11 wrote:New Android L is adding native USB music streaming. Sit tight for fall release unless you get a Nexus 5 and load the developer preview image.
Bumpity bump!TheMajesticKing wrote: ↑Tue Jul 15, 2014 10:26 amI've never had an issue with any of my android phones. Try pairing it this way.
Let me know if that works. There is more than one way to do it but that's how I've always done it with no issues.
Responding to a super old post...I don't think this is still possible, even with Nougat (haven't tried Oreo). I should try again once I go up to 8.0. The car is not able to read the phone storage...RCP97 wrote: ↑Mon Jul 07, 2014 5:08 pm...or head over to XDA and see if a custom ROM based off Android L (5.0) is available for your current Android device. That's how I'm heading when one is released for my Note 3....oops sorry...got carried away...wrong forumwideopn11 wrote:New Android L is adding native USB music streaming. Sit tight for fall release unless you get a Nexus 5 and load the developer preview image.![]()
...anyways it could be done (what the OP is asking) if you are running ICS or JellyBean, BUT your Android device needs to be rooted to be able to install one of the few apps that turns it into a USB Mass Storage Device in order for the car software to recognize the storage in your Android device. See, currently your tablet is most likely trying to hook up to the car as a MTP device but that wont work because your tablet is acting like a "mp3 player" instead of a "flash drive". Anyways as I stated earlier you could go to XDA Developers to get more info on this for your specific Android device.
...last, my take on this is that it would just be less of a hassle to either play ur stored music via Bluetooth or load it all on a flash drive...or both!
I am also on Pixel XL. They pushed 8.0 last week. You should have it by now. I haven't tried using the USB because I stream my music. My understanding was that only iPhones would work back then; not sure now. I will check though just out of curiosity with the Oreo update.Ilya wrote: ↑Wed Sep 06, 2017 6:26 amResponding to a super old post...I don't think this is still possible, even with Nougat (haven't tried Oreo). I should try again once I go up to 8.0. The car is not able to read the phone storage...
However, now that I'm thinking about it...maybe it's only phones that have expandable storage (external)...but phones with just one 'storage location' (internal) work fine? I'm on a Pixel XL right now.
Oh I can get it...I'm holding off because I'm rooted (Magisk) and have a custom kernel. Need to make sure everything supports O before I switch.armybrat wrote: ↑Thu Sep 07, 2017 4:08 amI am also on Pixel XL. They pushed 8.0 last week. You should have it by now. I haven't tried using the USB because I stream my music. My understanding was that only iPhones would work back then; not sure now. I will check though just out of curiosity with the Oreo update.Ilya wrote: ↑Wed Sep 06, 2017 6:26 amResponding to a super old post...I don't think this is still possible, even with Nougat (haven't tried Oreo). I should try again once I go up to 8.0. The car is not able to read the phone storage...
Cool - never got around to rooting Nougat...last root I had was on Marshmallow Note 3 since Samsung has so much bloatware. Might hold off rooting on Pixel XL for now. Seems to run fine as is. Bluetooth and phone calls work great with the M as well as my wife's Acura RDX. Only minor issue with Pixel XL seems to be with my LG wireless headset. Music will cut out intermittently only when the phone is holstered. My Bose wireless noise cancelling headset works great.Ilya wrote: ↑Thu Sep 07, 2017 6:23 amOh I can get it...I'm holding off because I'm rooted (Magisk) and have a custom kernel. Need to make sure everything supports O before I switch.armybrat wrote: ↑Thu Sep 07, 2017 4:08 am
