Would an VG3ODETT engine be able to fit in a 240sx?
DirftKing102
Car: Nissan 240sx 1993 convertable
My engine bay is big enough for a VG30DETT engine. But i just want to make sure I can put it in there before i buy one. Its twin turbos and everything. Do you think it would be able to fit in the 240sx? Please respond and tell me if it will or not. I have an automatic transmission so it should be able to work.
DRFT(kinda)
Car: 2005 Nissan Titan.
Yes.
edit: With any amount of money you can but any motor in any car. But a VG will go into a 240 for not a lot of money. If you search someone already did it.
Ohsoclean240
Car: 1991 240sx coupe
yesmy car before when the previous owner had a vg in it
you cannot run twin turbo because the drivers side turbo just happens to land smack dab in the way of the steering shaft
nightkid86
Car: 97 S14 SE
You can, but those things are a pain to work on in a 300, I can only imagine trying to work on one in a 240. Plus they are kinda heavy.
Ohsoclean240
well they are easier because you cant run two turbos... you have to run a single
the vg in my car made 519hp 485tq @ 22psi11.30 @ 129 (radials)
thats on a stock motor, just a fuel system and a big single
nismojunkie
this guy is in the process of making a kit to put the vg30dett in the 240. it keeps the tt too.
zerothread/187589
