rbspitfire »
https://forums.nicoclub.com/rbspitfire-u44060.html
Fri Dec 08, 2006 6:17 am
well i finally got my car running again after the bad ecu problem, and to my absolute surprise, a huge my rb20 spooled it up fine, its a 61mm(thats right i said 61mm) huge 84 t3 turbine and when its warmed up i can get full boost in second gear. you have to understand that my second gear is like youre 1st gear, 3.90 rear gears and 22inch tires equals first gear useless) the spoolup is pretty inpressive since the facts are: 2.0 liter engine, huge turbine, very low gearing, and very lightweight car ,1750lbs...i knew it was gling to be dificult so i wrapped the cast manifold to help spoolup.
